pulling my hair out on a cam choice
Old Aug 30, 2015 | 02:08 PM
69 nova's Avatar
Default pulling my hair out on a cam choice
i am building a 03 lq4 with 243 heads, stock bottom end, a ls6 intake , and 4l60e trans with 3.73 rear for my 2800-3000 pound 66 nova I Know its a over talked about subject, but i need some advise on a cam selection HELP PLEASE??
Old Aug 30, 2015 | 02:18 PM
JakeFusion's Avatar
Super Hulk Smash
StreetSweeper-HT 228/232 111+3... it'd make a ton of usable power everywhere in the range.
Old Aug 30, 2015 | 02:21 PM
Darth_V8r's Avatar
Moderator
I'd look at the titan5 from cam motion
Old Aug 30, 2015 | 02:58 PM
69 nova's Avatar
Thanks for the suggestions I've been watching the classifieds but everything that comes up is either too big or a newer cam I'm trying to keep costs down but looks like I will be buying a new one
Old Aug 30, 2015 | 03:45 PM
Exidous's Avatar
What's your stall? Do you care about fuel economy? How "lopey" do you want it?
Old Aug 30, 2015 | 03:57 PM
69 nova's Avatar
I don't have a converter yet was going to get on once the motor was done. Fuel economy doesn't matter to me I want it to sound good and pull hard I want to stay below a 3000 stall if I could
Old Aug 30, 2015 | 04:42 PM
96capricemgr's Avatar
What transmission? With a lockup/OD tranny I would do at least 3000stall 9.5" converter with a stock cam let alone an aftermarket.
Old Aug 30, 2015 | 05:28 PM
69 nova's Avatar
4l60e. This is my first ls swap I am use to the older stuff I ran a 2800 stall in my 69 but that was all old school stuff if I need bigger then a 3000 that is fine
Old Aug 30, 2015 | 05:39 PM
With lockup and overdrive a 3600 stall is likely to be a whole lot nicer on the highway than an old 2800 with a TH350. The deep first gear helps driveability with a high stall too.
You understand a decent stall probably starts at $600 right?
Old Aug 30, 2015 | 07:14 PM
69 nova's Avatar
yes i planed on spending some money on the trans
Old Sep 1, 2015 | 10:47 AM
Rise of the Phoenix's Avatar
Don't pull your hair. Have a guy like Ed Curtis or Martin Smallwood custom spec you a cam. As long as you provide them with the correct information on their custom cam sheet, they will do the thinking for you.
Old Sep 1, 2015 | 10:50 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Really nothing else to say to that...
Old Sep 1, 2015 | 10:55 AM
thunderstruck507's Avatar
A good 3600 converter will drive great.
A great cam for mostly "driver/cruiser" that would be tame manners wise but still have a ton of power everywhere:
http://store.cammotion.com/the-titan4
If you want a little more and have a good tuner or are willing to tolerate some small manners issues the Titan V or Penetrator would be good choices.
At the end of the day most mid size cams are going to be similar...not worth stressing over. Quality of the cam core and customer service are the bigger factor than minuscule differences in specs in my opinion.
Old Sep 1, 2015 | 11:11 AM
fst100's Avatar
could look into a lunati (voodoo) cam. before i sold my firebird, i ran their 232/238 off the shelf and i liked it in my LQ4 on stock compression ratio. with a 3200 stall and the car weighed 3560 with me in it and ran a PB of low 12.4ish at 115mph at cecil county dragway on 2.1x sixty with street tires. it has a nice low to mid power and idles nice.
eventually im going to get another lunati cam but not as aggressive as the one in the bird when i cam my camaro.
Old Sep 1, 2015 | 12:06 PM
DavidBoren's Avatar
There are professionals on here who get paid to do all the cam selection hair pulling for you. You will not get any better advice than to give one of those professionals your money.
That being said, I have heard nothing but good things about the cores/lobes/service from cam motion, and I would probably start with them.
Old Sep 1, 2015 | 01:11 PM
subeone's Avatar
i emailed martin 4 days ago already and still havent received a reply with any cam specs, was ready to buy a cam through him too. Go with pat and or ed to design you a cam.
Old Sep 1, 2015 | 01:41 PM
speedtigger's Avatar
Old School Heavy
I ran a 3000 stall for years behind my 6 liter. I like a little tighter converter for good street drivability. With your setup I would definitely recommend the Penetrator:
http://store.cammotion.com/penetrator
With 10 degrees of overlap it will have a nice lope to it. And, with a modest 43 degrees ABDC intake valve close, it will have excellent torque everywhere. I am a stickler for striking a balance between a great hotrod sound and great streetability. I think you will be very pleased with the Penetrator. Besides, when people ask you what cam is in it, you will be able to say "The Penetrator!" LOL.
