yet another cam question
Old Sep 15, 2015 | 08:26 PM
02sunsetorangeZ's Avatar
Default yet another cam question
I'm sorry! i can't find the info i really want. Im torn betwenn ms3, tqr v2, 233/239. It will be cam only for now, yes I'm going to upgrade push rods, springs, timing chain and oil pump. Hoping to get by with stock injectors, local shop said i should be fine so we will see. My main question, drivability isn't the biggest issue as its a weekend warrior. I like the peak power of the ms3 and was going to do a 111 lsa, but i don't really want to spin close to 7k. I'm feeling like around 66-6700. I would like to have roughly 390 to the wheels but also want power to really come on around 25-3000 rpm. Sorry again if this has been asked, been searching for a few days and can't seem to find the right answer.
Old Sep 15, 2015 | 08:34 PM
HCI2000SS's Avatar
Well bottom line the MS3 will make more peak power than the other 2, but at the expense of some low and mid range power. So only you can decide from there
Old Sep 15, 2015 | 08:39 PM
Darth_V8r's Avatar
Moderator
390 is fine on stock injectors. Near the limit but still ok.
Old Sep 15, 2015 | 09:13 PM
Alright, thanks for the info! I saw a dyno graph earlier where am ms3 kinda leveled off at 6500rpm, yet here people say it likes 7k. Any thoughts on this? I just really wanna have good useable power. I have 3.73's don't plan to go to 4.10's I like the way my gears are. What cam would yall think would give me that power band better?
Old Sep 15, 2015 | 09:21 PM
Darth_V8r's Avatar
Moderator
The cam I read getting rave reviews for good midrange power ("pulls like a freight train" and similar comments) is the Tick SNS2.
The ls2 version is 231/235, and would give you exactly what it sounds like you're after.
Old Sep 15, 2015 | 09:56 PM
A.R. Shale Targa's Avatar
http://store.cammotion.com/the-titan4
Since no 4.10s....this is what I'd consider
Old Sep 16, 2015 | 06:41 AM
Thanks again guys! I really like what I'm reading and seeing from the stage 2 sns. Seems like it would put me in the 390 range and perform real well. Makes great tq and power at great rpms. Gonna give them a call this afternoon to see what they think
Old Sep 16, 2015 | 07:46 AM
HCI2000SS's Avatar
Just remember not to get caught up in the dyno numbers game
Old Sep 16, 2015 | 08:11 AM
Rise of the Phoenix's Avatar
Unless you go with higher gears, I'd opt for the Torquer V2, but that's just me.
Old Sep 16, 2015 | 10:12 AM
Yea I keep telling myself that cuz I'm not gonna get dynoed either way so I just want it to perform great. I love how my gears are right now and from what I've read the power comes on around 2k rpm all the way to 64-6500 sounds great!
Old Sep 17, 2015 | 10:36 AM
TXZ28LS1's Avatar
I run the TSP 233/239...with livernois motorsports LS6 heads.. no complaints.
Its about the biggest cam i would run in a daily driver.
Old Sep 17, 2015 | 10:53 AM
kinglt-1's Avatar
If you are looking at Torquer cams I would probably opt for the V4 which is ground on a less aggressive lobe.
Personally I would stick with a cam around 228 on the intake duration . it is pretty much the sweet spot for good power, tq, and driveability for a LS1.
228r, Titan V4, Street sweeper HT, Tick SNS 2....etc. Lots of choices.
Old Sep 17, 2015 | 11:06 AM
Darth_V8r's Avatar
Moderator
Agreed. Up to 227-228, you get good gains for very little tradeoffs. Above 230, you start making larger trade offs for smaller gains.
Old Sep 17, 2015 | 11:19 AM
thunderstruck507's Avatar
You would love that Titan IV posted above, my roommate just got one for his trans am. Pulls great but also still drives awesome.
The MS3 does peak and level off around 6300-6400..but it carries out and to see the full benefit you would want to rev to 7,000ish shift points. I don't think it sounds like what you really want.
Texas Speed does have some other offerings which you might find to your liking (Torquer V4 is a new one that's good) if that is your preferred vendor.
