H/C install coolant leak - HELP!!!
I pulled the driver side plugs and rotated the engine a couple of turns to se if coolant was in the cyls. Nothing yet - so I unbolted the header. Ther was coolant laying in the bottom of the number 1 exhaust port <img border="0" alt="[barf]" title="" src="graemlins/gr_barf.gif" />
Any ideas? Every thing seemed to assemble normally.
Cometic gaskets - ARP studs - TEA 1.5 heads, new intake gaskets - new cam & pushrods & timing chain set.
Any ideas would be appreciated <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" />
I was hoping I forgot to put sealant on a bolt or surface or something. The job is so straightforward I cant see what I might have missed.
My gut tells me that the porting job broke through into a coolant passage - I don't know of any other way for coolant to get there unless the cylinder is also filled up - and this wasn't the case.
I'm going to throw on my pressure tester and see if the leak is visible in the port with a mirror.
This sucks <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Looks like the CNC hit water <img border="0" alt="[cry]" title="" src="graemlins/gr_cry.gif" />
I'll be calling Speed Inc. tomorrow AM to see if any of their other TEA heads have experienced this problem.
This has been the job from hell - my cam got bent during shipment too. (they made good for it immediately, as I'm sure they will with this dilema)
He was as suprised as me to hear about a thinwalled LS1 exhaust port. Chalk this one up to the LS1 R&D effort.
One of the main reasons that I went with TEA was the fact that they had plenty of very good heads running out there making GREAT power(and the price is right). They also have an outstanding reputation of standing behind their work.They deserve it <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I want to thank Brian for the rapid response to this dilema.
It looks like a small porosity in the casting is the culprit. It doesn't look like any inclusions are nearby (from recycled aluminum),so it's simply one of the age old problems in casting outside a vacuum.
Don't blame the CNC - the datum(s) used seems valid to me - and there is no way to see these porosities with out x-ray or other expensive means of core/casting validation.
Keep in mind that these jobs are kept affordable by skipping the all out max effort steps that you get for lots more $
Like I said before, they stand behind their stuff and I will continue using and advocating their products.
