Best route to make more power safety?
-PRC 2.5 heads
-Cam 235 240 .618 .615 111lsa
-650 dual valve Springs and chromoly pushrods
-ls6 intake stock tb and maf
-42lb injectors stock pump
-Ls2 timing chain
-ported ls6 pump
-lt headers with a cutout
-monster stage 2 clutch light weight flywheel
-bone stock bottom end
-arp head bolts but will go head studs if need be
Motor had 54k but does have pretty nasty piston slap on cylinder 1 until you drive it a 1/4 mile or so then it shuts up, piston slap has remained the same for the last 15k
The car made 448rwhp and 407rwtq now it's respectable don't get me wrong but I'm still not happy haha. I was thinking about a 100 shot of nitrous via wet plate kit/direct port kit but I feel like that wouldn't really last long term. Maybe an lq9 swap then nitrous but I really don't want the extra weight on the nose as its more of a road race/handling car well it was at least. Could I do a 408 or 383 stroker with the stock block and not worry about block failure at say 550-600rwhp. Idk just kind of stumped on the best route to take ideal budget would be about 2k I would do all work except for machining if needed. Also id be happy around 550rwhp but would like the option to grow into around 600-650 tho I doubt I'd go that far. It's a 80% street car 10% drag and would see the occasional open track day at road America ever other year or so. Thanks in advance.
If you were to stay NA, I'd tell you to go 102/102, but that won't get you 550. More like 460-470.
For your budget, to get to 550, nitrous probably your option. Maybe you could go fast 102/102 and nitrous and stay on budget.
25-30+(470-480 RWHP) all the time & more torque and throttle response
Through your whole power band 2500-6500 RPM.
Then add Nitous Outlet Plate Kit for a 100-150 shot when needed.
If you don't want nitrous you can get for around $1000 a FAST 102 combo and with getting rid of the MAF could pick you up some 15-20rwhp. Then add a set of gears and even though the car wouldn't make more power it would feel quite a bit faster.
That's your best bet of spending $2000 and making your car faster short of nitrous.
Probably find everything you need to know in there
