Street Heat 2 cam LS1 ptv
Old Oct 1, 2015 | 03:39 PM
LBCportagee's Avatar
Default Street Heat 2 cam LS1 ptv
I'm doing a cam swap on my LS1 just accumulating parts now and putting everything together. I looked through the cam threads but didn't see many examples of setups with the Street heat stg 2 cam. I have stock 241 heads/rockers/5315 morel,BTR dual springs. I want to bump my compression/quench as I'm going to be running E85. I plan to use a cometic .04 gasket. I called tick and they said recommended with that gasket not to mill more then .01 to .015 which I'm fine with. I'm just curious if anyone with Stock LS1's tested their PTV with the street heat stg 2 cam or did any milling to give me an idea how close it is? I know SNS2 cam is more popular but definitely different characteristics. SH2 spec 231/235 | .63x”/.61x” | LSA113+3....Thanks
