lq4 upgrades
Old Oct 6, 2015 | 07:31 AM
ozyo's Avatar
Talking lq4 upgrades
hi I have 93 k5 blazer with lq4 engine for offroding
month ago engine start losing oil pressure so I decided to change oil pump at the saime time I thought its good time to swap cam (with rocker arm,timing chain,lifters and valve spring ) not sure about future upgrades
this is parts list
-comp 54-452-11 XFI Xtreme Truck cams
-comp Ultra-Gold Aluminum Roller 1.7 Ratio Rocker Arm
-C7R Timing Chain
-comp 26918CS Valve Spring Kit
is this parts compatible what each other ?
do i need new pushrods and lifters ?
pls keep in mind im not form usa so im going to get all parts form amazon
Old Oct 6, 2015 | 08:04 AM
Tuskyz28's Avatar
I would look into the truck cams from BTR. They have great springs and and great cams. Call Brian ..... He might even custom spec you a cam to suit your needs. It's only 25 bucks extra to get that did.
Old Oct 6, 2015 | 10:12 AM
96capricemgr's Avatar
Also skip the rockers. This isn't a gen 1 that needs a rocker swap
Old Oct 7, 2015 | 01:59 PM
ozyo's Avatar
im not form us sir and to be honest stock lq4 more than enough for my need but i have some free time to burn
ok what about pushrods and lifters ?
Old Oct 7, 2015 | 09:21 PM
If you are changing cam then pushrods should be measured for and replaced, lifters are up for debate.
I would call someone other than Comp or Summit for a cam recommendation BTR would certainly be better.
Old Oct 7, 2015 | 11:06 PM
ozyo's Avatar
well I don't have anything to lose if I ask them
let's just hope they ship worldwide
