Bumping compression on ls2, TSP V2 cam?
Old Oct 11, 2015 | 11:16 PM
colt_impala's Avatar
Default Bumping compression on ls2, TSP V2 cam?
So after several months of contemplating and reading various forums and debates, I've decided to swap the cam and hand port my factory 243's on my 2006 LS2 C6. My question is pretty straight forward; Can I mill my 243's say like .010 to bup the compression slightly, and still use the TSP V2 without fly cutting?
Side note: I'll end up checking it for myself later before I put everything together, but was hoping someone would know off the top of their head if I'd have a PTV clearance issue with this set up.
Old Oct 12, 2015 | 05:50 AM
HCI2000SS's Avatar
Should be fine
Old Oct 12, 2015 | 07:02 AM
farmington's Avatar
you might check on what you can get your 243's cnc'd for before you hit them with a grinder.
Old Oct 12, 2015 | 10:30 AM
I'm debating on that. I've got the time and resources to do it, and there's a ton of info about DIY porting on here and other LS sites.
Old Oct 12, 2015 | 11:23 AM
thompson's Avatar
Piston to valve clearance after removing only .010 while using the Torquer 2 shouldn't cause any issues at all.
Old Oct 12, 2015 | 11:49 AM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
With stock valves or even 2.02 valves you should be fine at .010 milling with the Torquer V2.
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
