Morel 5315 lifters
Old Oct 23, 2015 | 11:47 AM
KCS's Avatar
KCS
Moderator
Originally Posted by kinglt-1
...Martin @ Tick...
Just FYI, he no longer works at Tick.
Old Oct 23, 2015 | 12:29 PM
Darth_V8r's Avatar
Moderator
Wait, WHAT???????
Old Oct 23, 2015 | 12:35 PM
KCS's Avatar
KCS
Moderator
Wait, WHAT???????
It was announced on Tick's FB page a couple days ago. I think he was let go, but it seems he left on good terms.
Old Oct 23, 2015 | 08:00 PM
kinglt-1's Avatar
Wow...did not know.
Old Oct 24, 2015 | 01:42 AM
Burken01's Avatar
hopefully he still sticks around here
Old Oct 24, 2015 | 03:47 AM
Quick Ranger's Avatar
I bet Tick will lose a lot of custom cam orders now without Martin there. Wonder where he will end up at?
Old Oct 24, 2015 | 08:06 AM
Burken01's Avatar
He's starting his own company, don't know if he is going to be a sponsor here just yet.. Hopefully he does since he has a huge following...
Old Oct 24, 2015 | 08:46 AM
KCS's Avatar
KCS
Moderator
Well, I think Jonathan did say they're going to put a hold on spec'ing cams except for in house builds. They still have a good line of shelf cams, so I think they'll be just fine.
if anyone thinks they can spec cams pretty well, I think they're hiring
Old Oct 24, 2015 | 10:46 AM
Darth_V8r's Avatar
Moderator
not just the cam specs, but didnt he come up with their custom lobes as well? I mean, I get it, people come and go, but I do think he will be hard to replace. Tick does a lot more than just cams so I'm sure they'll be fine. Martin is sharp guy. He will come out ok also.
Old Oct 24, 2015 | 11:54 AM
redtan's Avatar
I'm pretty sure they built a very good supply of cam/lobe profiles that unless were proprietary to Martin himself, Tick got to keep the rights to.
So while they may not be able to provide custom cams for a while till they get (if they do) a new cam guy, they still have a ton of proven designs that they can sell. With all the work they have done, I doubt there are many combos out there that they don't have a cam for.
I mean look at so many other vendors who's shelf cams are still popular today.
Old Oct 25, 2015 | 03:20 AM
Good for Martin, going out on his own. I know it was the best thing I ever did. I also had that "attitude" problem with employers, it really wasn't an attitude, I'm just good at what I do.
Tick customers will most likely be screwed if a customer gets one of the "whiney" Comp cams, I know in other threads Martin really helped get it warrantied.
Old Oct 25, 2015 | 11:08 AM
  #32
SoonerBrad88's Avatar
Martin helped spec my setup. He spec'd my cam and set me up with the 5315s, PAC springs, and some Trend 3/8" pushrods. Take the time and make sure your valvetrain is setup correctly and it will be support good power and be reliable.
Old Oct 30, 2015 | 03:32 PM
  #33
Cstraub's Avatar
Originally Posted by jhshnh
Chris, what Morel hydraulic roller lifter do you recommend for ls engines turning 7k plus?
5206. The lifter might be $400 more a set but $400 is cheap for piece of mind! It' no secret I do quite a few BBC pump gas cams a year. The valvetrain of a BBC is cavemanish to a LS. I have builds that are 10 and 12 years old with the cousin of the 5206 ( same identical body different tie bar ) and they see 6500 to 7200 in these BBCs.
