Comp Cams timing set...
Old Nov 11, 2015 | 08:38 AM
GbodyMandrew's Avatar
Default Comp Cams timing set...
i just bought a 7105 comp cams timing set adjustable billet blah blah anyways,
i keep hearing you need to shim this? i also have a melling high volume oil pump is there a trick to this shimming stuff or did they finally make a cover there you dont have to do much? thank you in advance all opinions and answers are welcomed
Old Nov 11, 2015 | 09:01 AM
KCS's Avatar
KCS
Moderator
You have to space the oil pump out if you use a double roller. The timing set should have come with the spacers if it is a double roller. FYI, be careful not to put them on upside down.
Old Nov 11, 2015 | 09:03 AM
heres another question you may know off hand...
lingenfelter gt2-3 camshaft cant tell what bolt it is
like this double roller set is for 1 bolt camshafts?
Old Nov 11, 2015 | 09:06 AM
KCS's Avatar
KCS
Moderator
What?
Old Nov 11, 2015 | 09:10 AM
http://www.ebay.com/itm/361240183389?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
thats the timing set i bought, pardon me im failry new to this ls and ls based stuff
the cam i have is a lingenfelter gt2-3
im basically asking will it bolt up to it or do i need to sell one of them?
Old Nov 11, 2015 | 09:26 AM
KCS's Avatar
KCS
Moderator
Comp Cams 7105 LSX Billet Timing Chain Gear Set Chevy LS2 58 Tooth | eBay
I don't know. I'm pretty sure you can grind just about any cam on either a 3 bolt or single bolt cam. The timing set is obviously a single bolt, so take a look at the cam and see if it has three bolt holes or just one big one.
