GM tolerance for valve stem tip height
Old Nov 16, 2015 | 08:53 AM
thunderstruck507's Avatar
Default GM tolerance for valve stem tip height
Working on a project that requires some precision in regards to valvetrain geometry down to the .001" range. Since my heads are worked including a valvejob on a head that had a couple pretty beat up seats I have a good bit of variance on a few.
Does anyone know how tight GM is on spec for valve tip height across a single head?
Old Nov 16, 2015 | 09:02 AM
KCS's Avatar
KCS
Moderator
I want to say it's +/- .010" or so. With higher lift cams, I don't think it would hurt to be taller.
Old Nov 16, 2015 | 09:21 AM
That is along the lines of what I expected. Most of mine are within a single thousandth but a couple seats needed a deeper cut. I think .007" was the most variance I saw but don't have my notes handy.
Just curious how accurate GM is on uncut heads to determine if these results are going to be easily duplicated.
Old Nov 17, 2015 | 07:46 AM
RockinWs6's Avatar
Keeping all the valve faces the same depth makes a difference in performance for sure. I always cut everything to match the lowest seat.
