Milling 241 Heads
Old Nov 19, 2015 | 03:04 PM
gpr's Avatar
gpr
Default Milling 241 Heads
How much can you mill off a 241 head? I'd like to mill the heads down to a 62cc chamber to get my desired compression ratio. How much would I need to tell the machine shop to take off?
Also by taking this amount off, is this going to weaken the head? Will be ran on boosted application.
Old Nov 19, 2015 | 03:41 PM
DavidBoren's Avatar
I have seen it stated that, generally speaking, .007" is equal to 1cc...
So, you want to go from 66cc to 62cc, that's 4cc difference. 4 x .007 = .028" of deck needs to be milled, if what I have read is accurate.
Old Nov 19, 2015 | 04:27 PM
96capricemgr's Avatar
Milling for boost? What shortblock?
Old Nov 19, 2015 | 05:40 PM
gpr's Avatar
gpr
Yes, all the pistons designed for boost are only 9:1 compression, and i need higher for my application. I'd like to get closer to 10:1 while still having a strong piston for boost and not needing to get a custom piston made.
Old Nov 19, 2015 | 06:58 PM
Why not just use a flat top forged piston? Might not be "made for boost" but neither are the stock hyper and see what guys do to those?
Old Nov 19, 2015 | 07:13 PM
gpr's Avatar
gpr
Because flat top pistons and dish pistons cost the same, so why put in pistons that aren't designed to handle the power I'm shooting for? Plus most flat tops will put me up at almost 11:1 compression.
