What else to get with a cam
Old Nov 19, 2015 | 10:56 PM
vlad1995's Avatar
Default What else to get with a cam
Hi, I know there are a million threads about this. But with all of them there and with most saying some things the same and some different, I just wanted to try to get a straight answer. So I know I have to get pushrods, valve springs, timing chain, oil pump. What else should I get if anything. thank you.
Old Nov 20, 2015 | 01:43 AM
Tuskyz28's Avatar
Sound like everything but gaskets and patience.
Old Nov 20, 2015 | 05:49 AM
MonmouthCtyLS7's Avatar
Definitely a million posts on this.
Old Nov 20, 2015 | 07:08 AM
cali_bear2003's Avatar
Oh just forget the new cam and just buy a new engine. Why install a new cam in a used up motor, I just do not understand that type of thinking.
Joking of course, just visit one of the sponsors sites and look at the cam kit. You pretty much have everything covers minus the crank bolt, fluids and needed gaskets sir 😀. Sorry, too much coffee in the first paragraph 😜
Old Nov 21, 2015 | 02:07 AM
welldonecj7's Avatar
Set of new lifters and possibly trunion upgrade, (depending on mileage budget and cam specs) a new cam retaining plate (if the gasket part is smashed),
Old Nov 23, 2015 | 10:48 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Just give us a call at Texas Speed! We can set you up with everything you need & we have a big special going on right now! How about over 18% off camshafts!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
