Using sbc 4.030 pistons
Old Nov 28, 2015 | 06:40 PM
Imdominant's Avatar
Default Using sbc 4.030 pistons
I have a set of 1.125 compression height 4.030 bore Mahle pistons , pins, circlips , & rings. (one of the powerpak sets that costs like $600-700)
If one were so inclined , could these be used in a ls engine platform? i assume they would have to be flycut? Its a -26cc dished piston and would be used in either a 3.75 stroke build or a 6.125 rod 4.0" stroke boosted build.
Old Nov 29, 2015 | 08:04 AM
KCS's Avatar
KCS
Moderator
I'd ask Mahle about that. I think the 4" stroke LS pistons have a specific skirt profile for the LS cylinder length. A SBC piston with a different skirt may not work out to well in an LS block.
Old Nov 29, 2015 | 12:36 PM
Imdominant's Avatar
Good advice! I didnt really think of skirt length, and forgot i heard something about how the 4.0" stroke puts the piston coming out of the cylinder at the bottom....
Old Nov 29, 2015 | 12:50 PM
KCS's Avatar
KCS
Moderator
Yeah, the bottom will come out but if the skirt profile is designed for it, it's not a problem. The skirt will be barrel shaped and as long as the fastest part of the barrel is still in the cylinder, you're all good. The problem here is that I don't think the skirt profile will be the same, but Mahle should be able to tell you that.
