build question
Old Dec 5, 2015 | 04:52 PM
sbf's Avatar
sbf
Default build question
i have two builds in mind which would be better.
1.441-445 with brian tooley tfs 245 mast 4500 intake llsr cam or hydraulic roller
2.ls3 416 with frh rhs small bore ls7 with mast 4500 llsr cam or hydraulic roller
Old Dec 5, 2015 | 10:13 PM
KCS's Avatar
KCS
Moderator
Better for what?
Old Dec 5, 2015 | 10:50 PM
sbf's Avatar
sbf
which will make the most power and be faster at the track
Old Dec 5, 2015 | 11:26 PM
Darth_V8r's Avatar
Moderator
I vote option 1, LLSR. The additional cubes will make more average power and those heads will certainly be able to feed the motor.
Old Dec 6, 2015 | 08:35 AM
KCS's Avatar
KCS
Moderator
It's probably pretty close. I think those RHS heads are really good, but I don't know if they'll offset that deficit of 20+ cubic inches. Now if those RHS heads went on the 440ci combo...
Old Dec 6, 2015 | 08:44 AM
Tuskyz28's Avatar
I say number 1!! TFS heads just don't shine on a shop dyno...... they kick @$$ at the track too.
Old Dec 6, 2015 | 05:30 PM
sbf's Avatar
sbf
Yea that's what I really want to do but 5500 on the bottom end and 8500 on the top end is not in the budget right now but I may just wait another year and just do the 441 with the rhs heads
sbf's Avatar
sbf
This is true
Old Dec 6, 2015 | 05:46 PM
Tuskyz28's Avatar
I have some LS7 headed combos fall short of 600 horse at the tire.....
While Vengeance and others was breaking 600 horse at the tire YEARS ago with a nice fat amount of torque down low in the RPM band to boot
Old Dec 6, 2015 | 06:41 PM
sbf's Avatar
sbf
all i want to do is run 6.20 or quicker on motor and mid to low 5s on nos thru a 4l80e in a 31-3300lb car street driven and ill be happy with that
Old Dec 6, 2015 | 07:26 PM
Tuskyz28's Avatar
A thread you might interesting then...
https://ls1tech.com/forums/dynamometer-results-comparisons/1033720-hke-pump-gas-445ci-tfs-235s-lays-down-574-482-a.html
Old Dec 6, 2015 | 07:37 PM
sbf's Avatar
sbf
https://ls1tech.com/forums/dynamomet...574-482-a.html
i talk to txcamss alot about the setup but im not sure if it would run what i want with the 80e and a stall that will take nos.he has a pg very loose stall
Old Dec 6, 2015 | 07:38 PM
speedtigger's Avatar
Old School Heavy
Either cubic inch combo will do it. The bigger engine will do it with less RPM. At those RPMs and power levels I would be looking at the LS7 stuff. I would not bother messing with cathedral at that power level. There is just no point in it. The LS7 format is just superior.
