Plan for my 5.3
-400hp (flywheel)
-Decent mileage
-Runs on cheap gas
-Can use stock converter
Because of the tight engine compartment, I will be using 1 3/4 headers. I had planned on using a Comp Cams 54-424-11 cam but am open to suggestions. Will I need bigger injectors at this power level? Should I look into finding a used set of 799/243 heads? Thanks in advance for any help or advice. Happy Holidays!
Here is a good article for you to read.
http://www.hotrod.com/how-to/engine/...st-comparison/
