What are you using for an oil pump o-ring replacement?
Old Jun 12, 2004 | 01:22 PM
SPANKY LS1's Avatar
Default What are you using for an oil pump o-ring replacement?
Just a regular o-ring, or does GM actually carry and sell just this part? If GM, do you know the PN? If using a regular o-ring, do you know the size? Any reason not to use a regular o-ring, such as fluid compatibility, heat, etc?
Thanks, Shawn
Old Jun 12, 2004 | 01:38 PM
Scalpel's Avatar
Thanks, Shawn
GM Part #: 12557075
