Looking for stock ring gaps on a
Old Jun 12, 2004 | 11:51 PM
Taspeed's Avatar
Default Looking for stock ring gaps on a
6 liter. I'm putting my shortblock together tomorrow....err starting it anyway. I'm upping the compression to around the 11.5-11.9 area and will probably go with 22 top and 26 second on the gaps. I wasn't sure on the stock gaps though. Anyone have an idea?
Thanks
Rich
Old Jun 13, 2004 | 01:14 PM
10secondZ's Avatar
Factory end gaps are .010"-.016" top and .018"-.025" second ring...for a higher compression motor like yours I would personally reccomend .020" top and .018" second for N/A and if your going to spray it..say up to a 150 shot..just use .006" of gap per inch of bore diameter for the top ring, and .005" per inch of bore diameter for the 2nd ring.Factory always runs a looser gap for the 2nd ring..but I prefer a tighter 2nd gap than the top for a tighter seal..plus the second ring isnt directly exposed to combstion heat..so not as much expansion occurs. Hope this helps,
Carter
Old Jun 13, 2004 | 11:50 PM
Elite_Hot_Rod's Avatar
Hey Rich,
This is Mark the guy you got the Holley Intake from. My 408 ought to be done by the end of the month if everything goes right. Where are you going to take it for test and tune?
Thanks
Rich
Old Jun 14, 2004 | 10:11 AM
Taspeed's Avatar
Originally Posted by Elite_Hot_Rod
Hey Rich,
10second-thanks for the info. I think I may spray it so I went with a 22-26 gap....an I broke 1 ring putting it in.
Mark- hey wuz up? Well test and tune is a little ways off. I've got to get an oil pan and headers. Not to mention I am still working on the porting of the heads. I should be ready in about 3 weeks if I can manage to stay in town that long I'm not going to cam it right away. I want to break it in first, not to mention I still haven't finished the rear end yet? Powdercoated that intake too
Old Jun 14, 2004 | 02:41 PM
10secondZ's Avatar
No problem..what kind of compressor and rings are u using? If it's a fixed compressor make sure your piston to wall clearance is not too loose or it could shift the compressor and snap a ring in a heart beat..Good luck and hope u enjoy the new motor!
Carter
Old Jun 14, 2004 | 02:47 PM
Taspeed's Avatar
I've bought and used several compressors over the years and I found that the 6.99 compressor that autozone sells is the easiest and most accurate one for the money. I broke my ring because I wasn't paying attention. The compressor wasn't pushed all the way down to the deck and the ring popped out of the side and broke my 2nd ring....no worries. diamond is sending me another ring should be together by the end of the week. OH...and yes I will enjoy it. Its been down since thanksgiving weekend
Old Jun 15, 2004 | 02:50 AM
mbaskett's Avatar
I told ya those second rings are easy to shear off!!!!
Deja-vu....
