Cam Identification Help
Old Jan 29, 2016 | 09:27 AM
2001 Z06's Avatar
Default Cam Identification Help
Can anyone help Identifiy this Cam?
it has the numbers 2871 F stamped on the end and then G5X2 hand carved into the end.
it also has the numbers NM246 stamped inbetween 2 of the cam lobes.
Any help is greatly appreciated.
Thanks, Joe
Old Jan 29, 2016 | 09:30 AM
2001 Z06's Avatar
Old Jan 29, 2016 | 11:28 AM
brobinson216's Avatar
Call LG directly and give them those numbers.
Comp Camshaft for the record.
Old Jan 29, 2016 | 10:52 PM
2001 Z06's Avatar
I found this information online.
Premier Performance Cams
G5x2 Custom Cam 112 LSA, 232 / 240 Duration, 595 / 608 Lift.
232/240 Duration & 595/608 Lift at 112 Lobe Seperation.
Computer compatible, billet steel, hydraulic roller camshafts.
Machined to fit all year LS1/LS6 engines.
custom spec cams manufactured by Comp Cams to our race proven specifications.
Add approximately 20-40 HP with no other modifications.
Comp Cam Valvespring Kit recommended.
The use of new lifters is not necessary unless there is significant wear to the factory units.
Applications:
1997 - 2004 Chevrolet Corvette
1998 - 2002 Chevrolet Camaro
2005 - 2010 Chevrolet Corvette
1998 - 2002 Pontiac Firebird
2004 - 2006 Pontiac GTO
