guys with milled 243s...
Imo you are better off running a slightly smaller cam with more compression and tighter quench then going bigger on cam and less compression due to not wanting to fly cut and running a thicker gasket.
once warm the cam does behave like a 234/242 113+3 so it has more clearance at times it will be turning RPM
also worth noting the heads had a valve job so they are a little more sunk in the head which should reduce valve drop
I have the GMPP ASA cam, so its on lazier lobes than the howards, but same otherwise (obviously). I'm thinking of milling my stock 243s .007 for a clean up, then running a .040 or .045 cometic. What was your clearances on the intake and exhaust? I really don't want to flycut, and I'm not too sure how far my piston pops up. It's going to be a fee months before the car is out of storage, but I'm trying to research and accumulate my parts. I haven't been able to find any threads with people having PtV problems with the ASA.
