Easy?
I'm not saying it's not cramped in some places, or that it's the ideal setup. But I think once you figure out a few ways to do the things that give people problems on it, that's it's not a world different than any other car. Could some things be easier and make you let some f bombs fly? yep lol But overall I don't think it's a deal breaker for me.
Edit: talking about an fbody ls1, I can't speak for the other two.
Cylinder heads under that cowl was tough the first time, but the second time was pretty smooth sailing.
Clutches are pretty good. I can drop the tranny with hand tools and a floor jack in two hours.
In general, the gasket system is very good. Don't have to do tons of scraping for the most part.
PCV leaves a lot to be desired.
The jobs that are surprisingly tough?
-oil pan gasket
-oil pump o ring
Second easiest is the Fbody. It looks crammed in there, but the only difficult thing to reach is the oil pressure sensor. You have to use a special tool and work blind to remove it.
Corvette looks like it has room, but believe me when I say that it doesn't.
You'll definitely need your jacksyands though, and my car is lowered so I use those rhino ramps once in a while too. They don't give you alot of room underneath, but you can do an oil change and stuff like that. I've even messed with my adj rear end components with it up on that ramps.
hardest thing on those would be the oil pan gasket and the driver side
header install. otherwise, piece of cake.
i've worked on a catfish, and main issue there, like stated, is half the
engine is under the cowl.. which sucks... but manageable.
