Rocker question
Ok, so I have a set of HS 1.8 rockers, and a set of new Cnc LS1 210cc/64cc heads with dual springs capable of .680 lift. Im going to install the on a stock 4.8 iron block. No cam, nothing else done. My question is, by moving from a 1.7 rocker, should my pushrod size go down from 7.400? Or would it go up? Im going to order a rod measuring tool from compcams because I didn't think about it in the first place like an idiot.
I understand this combo and route might grind a gear with some of you, but I am doing an experiment with the stock bottom end. lol.
Once you feel a drag (zero lash) then you torque the rocker down to 22 ft/lbs and see how many revolutions it takes
I like 1/4-1/2 a turn ideally but you can go over one full turn generally.
