Help me pick a new internal foundation...
Old Feb 20, 2016 | 02:32 PM
xdanny510x's Avatar
Default Help me pick a new internal foundation...
So by the looks of it my stroker is trashed.. collapased oil pump took out my bearings and scratched the crank..i had the eagle crank n rods and diamond pistons on there...pretty sure i need new rotating assemebly... im thinkin about the basic lunati stroker crank with like either callie ultra rods.... maybe some new pistons while.im there... i need some good pistons that would handle nitrous and boost... im hoping for at least 900rwhp to 1200..
Old Feb 20, 2016 | 02:41 PM
HCI2000SS's Avatar
Thompson Motorsports have great prices on rotating assemblies
Old Feb 20, 2016 | 02:56 PM
KCS's Avatar
KCS
Moderator
I'd try to figure out how the engine failure happened in the first place. You could just end up ruining the new parts if it happens again.
How did the oil pump "collapse"?
Old Feb 20, 2016 | 03:48 PM
L92 OLDS's Avatar
Roger that. I didn't know oil pumps could collapse. Did it implode? Pics and more info please.
Old Feb 20, 2016 | 06:01 PM
xdanny510x's Avatar
my bad ... i meant to say that the oil pump look stucked on the valve and then we seen that the oil pump screen was clogged .. so pretty sure it took the bearing out from starvation...Other than that would i pulled the valve covers off some of the rockers where loose.. so im not sure if that had to do with anything..
Old Feb 20, 2016 | 06:13 PM
KCS's Avatar
KCS
Moderator
No pics?
Again, oil pumps are supposed to stick. You're going to want to figure out the root cause before you put together a new engine.
