LSX Block with a 4.125 stroke
With your current cam, I would suggest you use a procharger vs a turbo. That's a lot of overlap, and very likely to fight the turbo. if you plan on changing the cam, then it won't matter, just get what you want.
Have you considered the MMS 235 Cylinder Heads with the
Nitrous/Forced Induction Exhaust Port? i think they are the
best Cathedral Heads especially for a 4.060" Bore and under.
They would run Awesome now and even more with boost
later.
