HELP! whining / squealing noise
Old Feb 28, 2016 | 08:32 PM
elcapetan's Avatar
Default HELP! whining / squealing noise
I'm experiencing a whining/squealing noise from the engine. It only happens after driving the vehicle around for 5 -10 minutes. I only hear it at idle, sometimes it goes away and can only be heard immediately after revving the engine. I though maybe it was a belt but it sounds like it is coming from the rear of the engine.
LS1 engine
Old Feb 28, 2016 | 09:58 PM
Russ K's Avatar
Remove the oil fill cap, if the noise goes away, then it looks like the PCV fresh air hose needs to be hooked up to the 90* elbow on the throttle body.
Russ Kemp
Old Mar 5, 2016 | 05:49 PM
joecar's Avatar
Also check for loose/broken exhaust manifold/header bolts (this lets exhaust to blow past the gasket, causing a squeal sometimes, seems related to throttle, and unrelated to rpm; at other times it causes a ticking sound).
Old Mar 8, 2016 | 07:54 AM
Old Geezer's Avatar
Intake torqued down?
Old Mar 9, 2016 | 02:47 PM
MIGHTYMOUSE's Avatar
you do not have a pcv fresh air point. you are dawing intake manifold vac on the crankcase.
