LS1 main caps directional? Help needed!
Do the main caps have to go back in the same place as original like a cracked end powdered metal rod? or can main caps be robbed from another motor?
The reason I ask is I found a LS6 block without main caps.
Also are the main caps between LS1/2/6 blocks the same?
Thanks,
Thanks,
