Help!,*keyway on the K1 tech crank.
Old Mar 9, 2016 | 07:35 AM
gallo-lo's Avatar
Default Help!,*keyway on the K1 tech crank.
What size key way on the k1 technology crank?
I know the back keyway is stock ,what size is the front slot??
Old Mar 12, 2016 | 09:27 PM
bluegrass trifive's Avatar
I'm not sure of the actual measured size but I can tell you it's the same as a small block key. If you need the actual dimension I can probably get it for you. Most auto parts stores will have small block keys and they're all the same.
Old Apr 16, 2016 | 11:45 AM
Stuntheavy's Avatar
Did you ever find an answer to this? I'm in the same boat, trying to install my IW balancer.
