Compression test on L33- this look okay?
Old Mar 9, 2016 | 09:16 PM
squashman702's Avatar
Default Compression test on L33- this look okay?
Ran a compression test tonight on the junkyard L33 with 799 heads I bought recently. Motor has 158k on it. Test was run on a stand since this is just a long block.
Numbers were as follows:
#1- 220
#2- 202
#3- 215
#4- 208
#5- 190
#6- 220
#7- 215
#8- 230
#5 is a good bit lower than most and has me a little worried. Plugs didn't have any buildup or anything on them, but definitely did not have much left on the electrodes. My mechanic friend suggested running a leakdown test- anything I should be looking out for on this motor? Seems pretty healthy other than #5.
Old Mar 10, 2016 | 04:11 PM
RockinWs6's Avatar
Number 5 just isn't as carboned up as the others.
Old Mar 10, 2016 | 08:58 PM
zraffz's Avatar
Carbon wouldn't result in a difference of 40 psi.
I wouldn't worry about it. Realistic causes are valve seats, cylinder out of round, small scratch in the cylinder wall from the ring ends, etc.
Old Mar 12, 2016 | 10:24 AM
Did the leakdown on #5, everything came back normal. Going with the FIRI approach.
Old Mar 13, 2016 | 07:05 AM
RockinWs6's Avatar
BS Those readings are all sky high from carbon! 158k I'll bet they are so caked the carbon hits the cylinder heads cold. Prolly knocks like hell on a cold start.
Decarbon the engine and they will come down to normal. Normal would be in 150-185 range. But since you have no idea how well your gauge is calibrated I wouldn't put too much stock in the readings regardless. The leak down tests tells all. Still needs decarboning though badly just from the difference in the readings.
