can I install the spark plugs on head before putting the head back on the block?
Was wondering if I can install the spark plugs before I put the head back on the block just to make it easier and if so what is the torque specs for the spark plugs? It's an ls1 with 241 heads
I rotate the motor while tightening the rockers back up so I get accurate torque readings. I try to get the lifters on the base circle of the cam so I'm not compressing the springs while tightening the rocker bolts.
