Will I mess up the timing?
Old Mar 29, 2016 | 05:37 PM
Lv99Z28's Avatar
Default Will I mess up the timing?
Almost done with the cam swap, my next question is will I mess up the timing? I lined up the 2 dots, now I have to unthread my crank bolt. Which will turn both gears. Will the timing get messed up if I do it like that? Again, just wanna be extra careful.
Old Mar 30, 2016 | 06:34 AM
vettenuts's Avatar
If I understand what you are asking, cam is in and cam plate is installed. Cam sprocket and crank sprocket with chain is installed and lined up. Bolts are in and tightened with red loctite on the cam sprocket. Then no it won't mess up timing, however best not to turn the motor over backwards. If you have a stick, put it in gear so the motor won't turn while removing the crank bolt. Shouldn't be that tight if you were simply rotating the motor with it.
Old Mar 30, 2016 | 09:07 AM
svede1212's Avatar
Don't know if you're confusing cam timing with ignition timing. Ignition timing is done off of the crank sensor. Cam timing is the valve events and is different. What you're doing isn't affecting either as long as the chain doesn't come off.
