Piston damage?
Old Mar 29, 2016 | 06:55 PM
occhevelle's Avatar
Default Piston damage?
I'm doing a head/cam swap and just got the head off. Today's surprise was seeing that the valves have been hitting the Pistons. I thought I knew about my engine (it's a swap) but I'm finding its not what I was told by the seller. I am putting ported 243's on there, but have no idea what heads were on it (the casting numbers are ground off). I'm assuming they were milled. Should I fly cut the Pistons or hope it'll be fine with the new heads?
Old Apr 1, 2016 | 07:15 AM
Old Geezer's Avatar
" Should I fly cut the Pistons or hope it'll be fine with the new heads?"
A "novel idea"......Check the clearance, and act accordingly.
Old Apr 1, 2016 | 07:24 AM
KCS's Avatar
KCS
Moderator
Run it and cross your fingers.
