Sled Pulling Rev Limiter - Help Needed
Very curious what everyone will say and looking for assistance as I didn't get very much help on Performance Trucks. Over the winter I have assembled an LQ9 and have installed it in my pull truck for sled pulling this season. The name of the game for me will be RPM to beat the Big Blocks, and I need everyone's help in figuring out how high this motor will spin and stay together. Engine Specs:
- LQ9 Stock Short Block w/ LS2 Style Floating Rods
- 799 Heads Milled to 60cc, Hand Ported
- LS9 Head Gaskets
- Manley Race Valves
- BTR Dual Springs with Titanium Retainers
- Manton Series 5 11/32" Pushrods, .040" Oil Restrictors in Machining
- Stock Rocker Arms with BTR Trunion Upgrade
- ARP Rod Bolts
- ARP Head Bolts
- Tick SNS Stage 2 Camshaft (231/235, .625"/.605", 111+2)
- 42lbs Injectors, NNBS Intake Manifold, 92mm Throttle Body
Imagining that the engine would run to whatever RPM I desired, what would everyone say would be a maximum RPM before eventual detonation is inevitable? I have read a lot and seen that everyone shifts around 7,500 on the 1/4 Mile, but when sled pulling I'll be maintaining that RPM for around 20 seconds, and I know that may begin to exhaust the valvetrain after sustained high RPM. RPM is ground speed for me, and the more speed I can get the better I'll be.
I'm wondering what everyone thinks about spinning this motor 7,200 and sustaining it for 20 seconds?
Any help or guidance anyone can approve is greatly appreciated!
Also, why did you get oil restricted pushrods? The lifters do the restricting not the push rods.
Which, incidentally, is another scenario where some people say oil-restricted pushrods are a good idea.
Likewise powerboats ?
I'm sure GM do much worse testing on their standard motors too.
Again no doubt there are hydraulic cams/lifters that could do that with ease..
Perhaps more important, oil, oil cooling, oil pump/flow, oil pan and engine cooling given you probably arent having a lot of airflow with that type of work ?
Surely whoever specced your cam should be able to tell you if your valvetrain etc is up to the job ?
And perhaps again on top of that.
There have been quite a few threads where people have bent rods on stock/SBE type motors when they've hit the factory ecu rev limiter. I've no idea what the ecu could ever be doing that might cause that to happen, but it is something to consider.
I'm sure you're working on that engine all of the time anyways. That will give you a little more power and a very stable valvetrain. It won't be cheap converting everything over, but I believe it'd be worth it in the long run.
Some good aftermarket heads to go with it, too
