Ls1 gaskets? What brand?
Old Mar 31, 2016 | 06:18 PM
MustangEater825's Avatar
Default Ls1 gaskets? What brand?
I have a 2000 ls1. 125k. Supposedly reringed around 105k(also has a cam). The car had a few leaks. Looks like front and rear cover. I have the engine out and on a stand... what are some. Common gaskets to go through while it is out, and what brands do you guys suggest? Read some complaints about fel-pro.
Old Mar 31, 2016 | 06:30 PM
conan's Avatar
If the engine is out and on a stand I would do all the gaskets, heads included, my $.02 But if you just want to do the most problematic I would do an oil pan gasket, front timing cover gasket and seal, rear cover gasket, and main seal, rocker cover gaskets. Check with some sponsors they offer kits, most are GM/Delco gaskets/seals.
Old Mar 31, 2016 | 07:46 PM
RollinSScamaro's Avatar
I've always heard to stick with GM or felpro. I've used both and haven't seen any issues
