Lm7 clearance question
Old Apr 1, 2016 | 08:01 AM
Ahmad99's Avatar
Default Lm7 clearance question
Hi guys
My plan for stock 5.3 lm7
Thunder Racing cam Trex V.2 - 242/248 .608/.612 110lsa +2
7.400 taxes speed pushrods
0.040 cometic head gasket
Ls7 lifters
Non toch heads
Do you think the piston will touch the valves or it will be fine ??
BTW -0.008 deck height 6cc piston volume
Heads chamber 61.15cc
Compression ratio 11.8:1
I will get 200 - 250 shot plate nitrous
Old Apr 1, 2016 | 08:20 AM
KCS's Avatar
KCS
Moderator
With a cam that big, I would just go ahead and assume the valves will hit and check PTV to verify.
Old Apr 1, 2016 | 09:38 AM
Ahmad99's Avatar
My question
Will the piston Touch the valve ??
Old Apr 1, 2016 | 10:17 AM
KCS's Avatar
KCS
Moderator
Yes, they will.
