Milling 243 heads
Old Apr 13, 2016 | 10:57 AM
Chris25's Avatar
Default Milling 243 heads
I am just finishing up porting a set of 243 heads and I am wondering how much I should have them milled to bump the compression up with the 228/232 cam I currently have in the car. The previous owner that I got the heads from said the heads have already been to a machine shop so I am not sure how much if any has been milled already.
Old Apr 13, 2016 | 11:29 AM
redtan's Avatar
Have the chambers been touched at all? If not, you can measure the cc on those and from there you can calculate how much was milled.
Old Apr 13, 2016 | 11:50 AM
Chris25's Avatar
The only thing in the chamber I have touched is the rough edges where the spark plug comes in that's it.
Old Apr 13, 2016 | 06:48 PM
redtan's Avatar
Then you should be pretty close to stock so CCing the chamber will tell you how much, if any, has been milled off the decks.
Old Apr 13, 2016 | 07:09 PM
Chris25's Avatar
Ya im going to mess around with that tonight. I want to to get it as close to 11:0 compression as possible and still have good ptv clearance.
Old Apr 14, 2016 | 02:42 AM
DaddySS's Avatar
You should consider the head gasket you plan to use and the desired quench area in determining how much you want mill. Mine wound up at 10.7.
Old Apr 14, 2016 | 01:31 PM
farmington's Avatar
there's a sticky up above that will help with numbers
Old Apr 14, 2016 | 02:12 PM
Chris25's Avatar
Thank you I have read through it. Looks like they haven't had anything milled at all.
