Turbo LM7 Build- HELP
Not a big deal to some but is a huge deal to me. SO, I will be using the Stock Cylinder Heads, and bottom end.I also want to still use the Stock Converter, and will be using a map for 91 Octane only. I will be moving to forced induction with the On3 Performance Turbo Kit and standard 70MM, and accessories included with it. I have questions regarding, push-rods, lifters, camshafts, valve-springs, and fuel delivery (injectors and fuel pump choice). I plan to only push 10-12 PSI as it will be a street truck and daily driver with fun. What do you guys recommend for these things regarding Brand, and Specs? Are their any package deals out there? Help me get this going! Thank you Last edited by LM7Guy; Apr 20, 2016 at 10:06 PM.
