Rockers
Old Apr 25, 2016 | 08:44 AM
moekluse's Avatar
Default Rockers
Not going with stock rockers on this build. What should i get. Looking for rocker that can withstand high power. No idea what ratio
Old Apr 25, 2016 | 09:00 AM
JoeNova's Avatar
Restricted User
High power? Power doesn't have much effect on rockers. RPM does.
Old Apr 25, 2016 | 09:05 AM
moekluse's Avatar
Ok cam is rated for 6800 rpm
Old Apr 25, 2016 | 09:17 AM
JoeNova's Avatar
Restricted User
'Rated' means absolutely nothing. RPM peak will depend on cubic inches, head flow, intake manifold, exhaust manifolds, etc. You can take a cam 'rated' for 6800 RPM, throw it in a 408 stroker and power will peak and start falling by 5500 RPM.
If you're really worried, just get trunion upgrades for the stock rockers.
Old Apr 25, 2016 | 11:08 AM
KCS's Avatar
KCS
Moderator
How do you expect to get good suggestions if you don't go into detail as to what they're going to be used for or what your budget is?
Old Apr 25, 2016 | 11:13 AM
IDriveChevy's Avatar
Trunion upgraded stock rockers will be just fine.
Old Apr 25, 2016 | 12:24 PM
moekluse's Avatar
I dont have the stock rockers. Im doing a turbo 5. 3. 317 heads. All forged. Big lobe cam. Not sure on intake yet. Just looking for strong low priced rockers
Old Apr 25, 2016 | 01:05 PM
JoeNova's Avatar
Restricted User
Please read on camshafts and turbos. You already sound like you're off to a bad start... They do NOT like camshafts designed for N/A engines.
Old Apr 25, 2016 | 01:12 PM
moekluse's Avatar
Sorry i got mixed up with my 5.3 builds im building. Its actually a howards turbo cam. The same cam in the 4.8 with twin 76s and stock bottom end that made over 1k.
Old Apr 25, 2016 | 03:00 PM
KCS's Avatar
KCS
Moderator
I'm using Comp's Ultra Pro Mag rockers in my build. They're steel 1.8:1 ratio rockers, so they're stiffer than aluminum rockers but they're profiled to keep the weight only marginally more than aluminum. They won't fatigue like aluminum either, so you don't really have to worry about them breaking either. I bought mine for $345 from a sponsor.
Old Apr 25, 2016 | 04:18 PM
dailydriver's Avatar
Some have even told me that the NOT trunnion upgraded stockers are just fine as well.
In my 185K factory LS1, it was the LIFTER'S rollers that lost their needle bearings due to hard use/high revs, NOT the rocker trunnions, they are STILL perfect!
Old Apr 25, 2016 | 07:48 PM
moekluse's Avatar
I need rockers and lifters regardless so im just looking for some good bolt in stuff. Any suggestions, i would like something around the 200$ mark
Old Apr 25, 2016 | 07:51 PM
moekluse's Avatar
What are sone benifits of going with lets say a 1.5, 1.6, 1.7, or 1.8 ratio rocker. Not very familiar with what the differences are. Thanks
Old Apr 25, 2016 | 08:49 PM
big hammer's Avatar
Stock is 1.7 on the 5.3. Going to a 1.8 rocker will increase lift. If you already have a high lift cam then adding 1.8's could make your Pistons hit the valves.
Old Apr 25, 2016 | 10:22 PM
joecar's Avatar
Default Rockers
From the CStraub rocker bushing upgrade thread:
http://cimg3.ibsrv.net/gimg/ls1tech....c6301f8bd1.jpg
https://ls1tech.com/forums/generatio...nion-kits.html
Old Apr 26, 2016 | 06:49 AM
moekluse's Avatar
Would 1.5 or 1.6 be my best bet
Old Apr 26, 2016 | 07:02 AM
JoeNova's Avatar
Restricted User
And you made over 1k at the wheels on your 4.8?
Old Apr 26, 2016 | 07:14 AM
KCS's Avatar
KCS
Moderator
Yes...go get a set of 1.5:1 rockers.
Old Apr 26, 2016 | 07:29 AM
kinglt-1's Avatar
Google the pros of high ratio rockers and start reading. If you have to replace everything now I would probably opt for standard 1.7 ratio and get a matching cam. In my case, I already had a nice set of SLP 1.85's that a previous owner installed, so I bought a cam designed to work with them. The valve train is a system of components, get it all working together appropiately and you will have a good running motor that will last a long time.
Next question you need to ask yourself is how much time and work do you want spend setting the valve train up? Going to a Yella Terra or shaft mount will require shimming to get the right wipe pattern. Where stockers are pretty much bolt-on and go. Hence why most opt for these with upgraded trunions. Some roller rockers are heavier over the valve then stock, which needs extra measures taken for proper valve control...another reason why most opt for upgraded stockers.
Old Apr 26, 2016 | 08:26 AM
MonmouthCtyLS7's Avatar
Another vote for just a trunion upgrade.
