Need experienced help/advice after having my 98 t/a engine replaced
Old Apr 29, 2016 | 09:19 PM
FlynT/A1998's Avatar
Default Need experienced help/advice after having my 98 t/a engine replaced
Ok after $2500 replacing this thing im scared something might be wrong with my engine again. I have noise coming from the engine that i was told was the a/c compressor but after removing the belt its still there. Ive tried tracking it down with a stethoscope from uptop but nothing yet. I guess ill start with what i know is wrong with the car then try to explain the noise it's making. First ill start with my auto trans, when cold it shifts so-so. Bit after 2-4 mins when u take off from a stop it just goes upto 3-4k rpms an about 20 mph then u have to let off the gas to get it to shift if it doesn't sometimes u hve to feather the gas a little like revving up n letting off till it goes. The shift from 2nd to 3rd also slips but not nearly as bad. I know its shot. But heres where the tapping/ knocking comes in. It's barely noticeable when started up cold if at all. After about 2-4 mins around when the trans starts acting up when i take off i hear this ta ta ta ta noise from the engine. It speeds up with the rpms and slows with the rpms as i work it into shifting to second, then if i give some gas say 3k rpms u hear the ta ta ta ta noise but not as loud. Once it shifts into 3rd i don't think i hear it all wether taking it easy or accelerating to 60-65 quickly and cruising it seems to almost disappear until i alow down an trans down ahifts. Now when i come to a stop while in drive an everything warmed up i can hear it faintly sitting there. Ta....ta....ta then when taking off again ta..ta..ta..ta almost faster than the rpms. I have put trans in rev warmed up an backed up fat spinning wheels an don't believe i hear it then. Could this be in the trans? Instead of the engine? Cold start up i have 40-43 psi on factory oil guage once warmed up it sits at 22-23 psi an shoots past 40 when I accelerate. An warm at about 1500 rpms i have 33-35 psi pressure. Below are the details on the engine swap etc...
Started factory 1998 t/a ls1 engine that hydrolocked at 81,000 miles.
Replaced that engine with a 1999 z28 ls1 engine.
Mechanic said he used the 1999 z28 bottom end and heads but swapped the 1998 t/a intake manifold and fuel rails/ injectors an throttle body over to the 1999 z28 engine and then installed into my car. And thats where i am today.
Im hoping something rings a bell with you more experienced ls1 guys hear, or naybe some tips to narrow it down? Someone said I should of had to use the pcm from the 1999 Camaro for some reason, any truth to that? I believe they also used the 99 z28 exhaust manifolds aswell. I dont see anything in the oil after pulling the dipstick after driving a few miles an wiping it on a clean white piece of paper. Thanks for input you may have.
Old Apr 29, 2016 | 09:31 PM
Darth_V8r's Avatar
Moderator
My first thought is torque converter
Old Apr 29, 2016 | 10:25 PM
outkast6991's Avatar
Or loose/ broken flex plate. Also check your fluid level for the shifting issues if they weren't there before
Old Apr 30, 2016 | 01:58 AM
Yea it's been shifting like that for about 300 miles now, I may try changing the filter idk if it's worth it or not, i did take about 4-6 quartz out through the dipstick fill tube with a transfer pump an replaced with fresh fluid and a bottle of lucas oil treatment didn't seem to make much a difference. Guess I'll have to find a way to get it up in the air tomorrow to check the converter bolts and flex plate. Ill also post a video from when i start it an keep filming while i drive a few miles if that would be helpful. I do have a small roof to do tomorrow so it won't be until sometime afer say 2pm
Old Apr 30, 2016 | 02:00 AM
Any ideas about the pcm i heard about? I was told because i used a 99 engine an my cars a 98 that I should of swapped those aswell
Old Apr 30, 2016 | 07:04 AM
Only if you changed the wiring harness.
Old May 1, 2016 | 09:54 AM
SlasherVRGR's Avatar
If he didn't swap your 98 oil pressure sender don't go by the factory gauge.
The 98s had a much more accurate 2 wire sender, where as the 99+ cars got a 1 wire sender with a dummy gauge on the dash.
Old May 1, 2016 | 10:14 AM
LLLosingit's Avatar
If your going to have the car up in the air to check the converter bolts you might want to try unbolting the converter and push the converter forward a little and then start the car with it unhooked. This will let you eliminate the trans as the cause of the noise.
