Help picking pushrod length
My question is what length pushrod should I order? Should I run less preload and order 7.375 or run stock length at 7.4? The spec that came with the lifters is .045-.050. Im plan on ordering Manton 11/32 pushrods if than matters.
This is my first time doing this so I want to make sure I get it right.
Thanks
If you really want to optimize, measure all 16, and when you get the pushrods, put the shorter ones and longer ones where you need them. Optimization is time, but it frees up ponies.
I installed 2 stock pushrods in one cylinder and the rockers felt pretty good to me. I also turned the motor over to make sure it didn't bind up.
Oh and sorry if these are dumb questions!
