6.0 lq4 question
Old May 1, 2016 | 03:03 PM
hunterson500's Avatar
Default 6.0 lq4 question
Do I have to have a higher compression setup with running a cam with a 261 intake and a 265 exh
Old May 1, 2016 | 04:17 PM
Darth_V8r's Avatar
Moderator
Is that the duration at 050? You don't HAVE to, but higher compression will alleviate some low rpm drive ability issues
Old May 2, 2016 | 09:51 AM
Mercier's Avatar
Compression is basically free power..why not run as much compression as feasibly possible for your intended operating conditions and available fuel? Running a carb or are those gross numbers?
