Swapping cam gear. Quick question
Has anyone ever swapped the cam gear without completely removing the timing cover? I'm hoping I can just take it loose and rotate it to the side to swap the gear. Trying to avoid taking the pulley off as I don't have a pulley puller or installer immediately available.
I doubt there is enough room to get to the bolts and remove the gear. More importantly you don't want to be at a weird angle when taking the bolts out as you don't want to risk dropping the bolts down into the oil pan.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Fair enough. Didn't think about the bolts falling into the pan.
You cant pull it far enough forward with the pulley on to rotate it, because the oil pan flange prevents you from doing so. Buy a 2 pc cover if you want to do it easy in the future.
