N/A cam with a turbo?
'thanks in advance
Having said that, the cam you have has 8 degrees of overlap. Honestly I would let it fly for the initial install and then get some backpressure readings to spec out a good cam for it.
However, experience shows otherwise. There are many engines with high backpressure ratios which will also show impressive improvements to flow with more overlap. Some great examples are the well known sr20/4g63/2jz platforms, which all come in some form or another turbocharged, and all respond well to increased overlap despite high ExGasPress ratios and OEM style manifolds being retained. It might be that the head/ports are more well suited to flow like that (they come turbo, with 4V/cyl head, just a guess) or perhaps its something to do with the whole combination (exhaust gas velocity or port acoustic tuning, another guess) mainly, just be aware that the rule of decreasing overlap for high pressure turbines is not hard or fast.
