First engine build
Old May 17, 2016 | 11:56 AM
silvy13's Avatar
Default First engine build
Im building my first engine and need some help guys im starting off with a stock bottom end lq4 and i plan on putting some 799 heads milled .30 or .40 with a 228/232 112 with ls9 gaskets my question is will i run into any problems concering the pistons and valves ..i plan some spraying it thats why i wanna go with ls9 gaskets and also what will be my cc
Old May 17, 2016 | 12:08 PM
svslow's Avatar
There is some good info here,
https://ls1tech.com/forums/generatio...tv-issues.html
Old May 17, 2016 | 12:19 PM
silvy13's Avatar
So the cam will work with the heads milled .30 but what about the gaskets will that help out too ?
Old May 17, 2016 | 12:37 PM
svslow's Avatar
I don't think the gaskets will make a difference.
