Cylinder head problems
Old May 20, 2016 | 10:03 PM
transwiz's Avatar
Default Cylinder head problems
I have some cylinder heads that were on my t/a. I took them off because the guys that did my motor mods screwed everything up.They are ported and milled 317 castings. The valves were too big(2.08") intake. Anyway, I took them off because someone tightened the rocker arm bolts with a breaker bar.A couple of them stripped in the heads.
Here is a picture of the exhaust bolt hole. Can this be welded or put some type of helicoil. How would these be fixed? How
much trouble would it be ?
Attached Thumbnails Cylinder head problems-p5200003.jpg   Cylinder head problems-p5200004.jpg
Old May 20, 2016 | 10:45 PM
64post's Avatar
The end exhaust bolt hole looks to be too big now for an 8mm Time-cert. Weld them up and re drill them, many machine shops can do this.
Old May 21, 2016 | 12:43 AM
transwiz's Avatar
What would something like that cost?
Old May 21, 2016 | 01:30 AM
Burken01's Avatar
Just buy a $30 helicoil Kit from autozone
The next size up from the stock 8mm thread is a 10mm x 1.5 pitch
It should work, you'll just have to drill open the bolt hole on the header flange as well to accommodate the bigger bolt
Sent from my iPhone using IB AutoGroup
Old May 21, 2016 | 08:32 AM
joyridin''s Avatar
Use a heavy duty Keensert. It has a large outside diameter. Drill, tap, install Keensert, and you are done.
