engine won't run
Old May 21, 2016 | 10:39 PM
hoonigann's Avatar
243. Idk who they were installed by. I've put about 15000 miles on the car since I bought it and this is the first time the engine has had any issues
Old May 21, 2016 | 10:47 PM
Burken01's Avatar
Yeah those heads never came on that car originally, but they are better heads than the factory 241 heads for 01-02 fbody cars..
So back to the problem at hand.. Lol
It's really tough to diagnose a engine tick over the Internet, maybe take a video?
Old May 21, 2016 | 10:48 PM
hoonigann's Avatar
Give me a minute and I'll post one
Old May 21, 2016 | 10:49 PM
hoonigann's Avatar
Scratch that. Give me 10 minutes. I still have to put the valve covers back on
Old May 21, 2016 | 10:53 PM
hoonigann's Avatar
I forgot I'm still cleaning the valve covers. I'll post a vid tomorrow after I change the oil
Old May 21, 2016 | 11:07 PM
Burken01's Avatar
This is the time when your going to learn to start working on cars..
I think most of us here started because they ran into an issue and didn't have the cash to take it to a shop..
I started really working on cars when a known shop in my area gave me a 2k estimate to do a cam swap back in 2004
Old May 21, 2016 | 11:11 PM
hoonigann's Avatar
Lol I like to think I know a bit. I changed out the clutch master cylinder myself and I've modded multiple cars in the past.
My experience is in suspension and brakes, not engines tho hahaha. Time to learn I guess
Old May 22, 2016 | 12:10 AM
LLLosingit's Avatar
, the engine made a loud tapping noise and shut off. it then would start after lots of cranking and throttle input but would only run for a second or 2 making a horrible tapping sound.
Doesn't sound like a valve train issue to me, Usually they will run with a broken rocker arm or bent pushrod. Horrible tapping sound makes me think it's much more serious than that. I would run a compression test to see if you can narrow it down to a certain cylinder and then go from there. If it's more of a knocking sound rather than a ticking sound I would guess something let go in the bottom end.
Old May 22, 2016 | 12:12 AM
hoonigann's Avatar
I'll try that as well
Old May 22, 2016 | 12:47 AM
hoonigann's Avatar
and ya its much more of a knocking
Old May 22, 2016 | 12:57 AM
LLLosingit's Avatar
Let me guess, You had it in second gear and ran it hard to 5,000rpms and then just let off the gas and let the engine slow the car rather than pushing in the clutch and coasting?
Old May 22, 2016 | 12:58 AM
  #32
hoonigann's Avatar
Yup. But engine breaking shouldn't kill an engine
Old May 22, 2016 | 01:08 AM
  #33
LLLosingit's Avatar
I've seen it happen many times.
Old May 22, 2016 | 01:23 AM
  #34
hoonigann's Avatar
I understand how it could break an engine but I'm a bit baffled that you have seen in multiple times. It doesn't seem like a common occurrence
Old May 22, 2016 | 01:36 AM
  #35
hoonigann's Avatar
According to a quick Google search, engine braking does not harm the engine unless you over rev it when downshifting (which I didn't do)
Old May 22, 2016 | 07:36 AM
  #36
LLLosingit's Avatar
It's not common but I have been around racing for most of my life.
I couldn't even tell you why it happens but I have seen many engines blow as soon as the throttle is lifted. I don't know if it has anything to do with the sudden vacuum surge when the throttle blades close causes it or possibly there is enough slack in the timing chain that when you lift hard that it the slack allows a valve to kiss a piston.
Old May 25, 2016 | 08:13 PM
  #37
hoonigann's Avatar
Ok so I unplugged the ignition coils and cranked the engine with the starter and there was no noise. Plugged em in and started the car and I found the source of the knocks to be the trans. Flywheel falling off the engine or pressure plate issues
Old May 26, 2016 | 06:11 AM
  #38
joecar's Avatar
How did you determine this...?
Old May 26, 2016 | 01:30 PM
  #39
hoonigann's Avatar
I had a friend start the car for a brief second and listened carefully to find where the noise was coming from. I totally could be 100% wrong so it's just a theory right now until I remove the starter and see if I can look at the flywheel. Still kicking around other ideas. Changed the oil and the oil has no metal bits and the filter is clear too
Old May 26, 2016 | 03:39 PM
  #40
hoonigann's Avatar
Fbskncejksnfaknfbejshfbfnwb
So my smart friend suggested I take off the starter motor to have a look at the flywheel before I drop the Trans, pulled the starter off and found that it wasn't fully disengaging from the flywheel
