General info about cam an its potential?
Also another question which upgrade would be best used 800$ a fast 102 intake manifold, no tb i can get ebay one, or torque converter plus intstall?
Well & 5 to dyno tune lol
Thanks.
While exhaust duration bias can be seen as boost-friendly, it doesn't make it a boost cam necessarily. In #1 LS2 in the Jeep(basically just a 6.0 version of what you've put together there, I ran a 222/228 naturally aspirated because I couldn't get long tune LS headers to fit a CJ. With 1-5/8" shorties and 2.5" duals, we put more exhaust duration in to make up for the intake side flowing better than the exhaust. My LSA was a little tighter so your cam will favor a little higher RPM but that should be a real nice cam for 243s.
As I think you hinted in your post, that cam will not only benefit from, but basically require a tune.
A stall in the 32-4000 range (depending on how you use the car) will make a huge difference.
Hell, I bought a $199 revmax converter and beat the living snot out of it for years with a 450rwhp car both at the dragstrip and road course...and it performed like a champ. You can't honestly say with a straight face that a converter costing 4x as much is a "cheapo".
You must be thinking of a different platform alltogether or triple disks.
The guy said no good converters arw around 800 so i disagree and put yank as a example..
Also circle d has them for 450 on there site
Hell, even a $450 one like you mentioned will be more than fine for street and light track duty. You don't need a $1400 triple disk monster to putt around town.
