internals needed for 10's in 98-02 fbody
Old May 27, 2016 | 07:27 AM
sillysspeed's Avatar
It is definitely possible op. How does you car run now?
Old May 29, 2016 | 07:41 PM
cals400ex's Avatar
My car that I recently sold did run 10's stock weight, but it had full bolt-on's, cam, 317 heads, and a P1SC procharger. Before the procharger I had full bolt-on's, 224 cam, TSP 5.3L heads, and a yank 3800 stall and it ran 11.80. That was a full weight car. Since then, there have been some advancements in cam and head technology, and I know I could get a little more out of a different stall. Regardless, I was just looking to see what it took to get to 10's NA. I'm still unsure if I'll go with a NA or procharged setup. Since I'd use this car on the street, I'd rather it run mid-11's and be more "streetable" with better reliability.
Old Jun 1, 2016 | 12:52 AM
NitroFumesAteMyBrain's Avatar
just go turbo and be done with it. my SBE, stock head/cam just made 585/598 on 10# and 15* of timing running e85, safe as all hell. should crack 10s without too much hassle and drives like stock until you drop the hammer.
Old Jun 1, 2016 | 01:44 AM
Exidous's Avatar
I'm a little worried now about not having a cage...
I'm at 3000lb and a full mamo top end and high 220's cam and no cage. Guessing I won't be allowed back next time I go to the strip...
My only issue right now is 4th tops out at 117MPH.
To the OP: FI or Nitrous will be cheaper than N/A on a SBE. You have to have a top of the line top end to pull it off full weight. Optimization is everything. FI or NO2 will make it stupid easy.
Old Jun 1, 2016 | 06:10 AM
JoeNova's Avatar
Restricted User
I'm in the same boat. As long as I shed some weight before I hit the track, I will have the power and weight to run an 8-second pass and I don't even have a roll bar LOL.
It sucks caging a street car...
Old Jun 1, 2016 | 12:16 PM
jhshnh's Avatar
You can do it with stock bottom end, and close to stock weight. The 3 things you have to have are 60' time, weather, and power.
Suspension and weather are definitely key. It'll be hard to run 10s in 90 degree weather with a high density altitude.
You would need to pull 60's in the 1.5s, so suspension and tire choice are key.
Where you live as far as weather is concerned is key. My car is n/a and it runs quicker times in 50 degree weather than 80 degree weather. I'm fortunate living on the east coast because from November to March I can run in cool dry weather, and at times have a negative DA.
