New Engine build
hello all its been awhile since ive needed help, so here we go, i have just finished building a modded ls1 for my 2001 trans am. my question is i have went from stock 26lb fuel injectors to 42 lb injectors. The mods are as follows
1. replaced stock 241 heads with port and polished 243 heads flowing at 61cc chambers.
2. installed a custom grind cam specs. 228/237 114LSA .626/.626
3. long tube 1 7/8" to 3" collectors.
I have ran the engine for about 5 min. i have been told that if i do not tune the pcm to the new injectors that i will wash excess fule down the cylinder walls and possibly damage the rings and dilute the oil. Any information on this would be great and also by running the engine for the 5 min will i have damaged anything.
Vendors told me I'd be fine with idling or even driving it easy (low rpm). I drove mine around town a few times and 25 minutes to my tuner when I swapped to bigger injectors, heads, intake, etc. Just don't go WOT or anything close until you're tuned.
Get a tune...don't drive around or run it on stock injector parameters no matter if somebody said they have. If anything you can get a base tune from a sponsor here such as LSX power tuning and then take it to a dyno shop.
thanks Kinglt-1 im going to go with your suggestions I called your guy and im going to send my PCM to LSX Power Tuning then take it to your guy for a final tune thanks again brother for the solid info.
check the oil for fuel wash/smell
change it out to some good break in oil and get your start tune in the vehicle
if i mail my PCM to Lsx Power Tune how close will this tune get me and will i be able to break the engine in before getting a final tune and if so how long untill i will need to take it to a dyno for the final tune?
Port and polished 243's 61.5cc
custom ground cam 228.4/237.0 @0.050 113.7 LSA .626/.626 lift
4l60E transmission w/2500 stall
1 7/8" longtube headers into 3" collectors
Bosh 42# injectors
Bosh 42# injectors
