Cam install.. how Much?
Old Jun 18, 2004 | 05:22 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Local performance shops start @ $800 around here.
I paid for my first cam swap.
I read ls1howto.com and made friends with someone who had done a cam swap already for my second.
I charge $150 for cam and springs. i've done about 30.
I might just have to drive to Texas for a vacation if I decide to do a 3rd!
Old Jun 18, 2004 | 06:03 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Originally Posted by SUX2BU
Hell, during the superbowl i did TWO cam and spring jobs on two cars at the same time in around 7 1/2 hours.
They were actually swaping cams and springs so i gave them a package deal of $250.
You Rule!
Old Jun 18, 2004 | 07:04 PM
JEB99TA's Avatar
Default Went to Lamotta's today ....
Talking with the folks at Lamotta's today, in Longwood, Florida (where they did my cam), they were willing to show me that they charged $60.00 per hour. The book time for the cam install came out to $974.00. GM dealerships here charge the same hours and $84.00 an hour. I've researched it pretty thoroughly.
I spoke with Jake Lamotta, the owner. He's a really down-to-earth guy. The original quote (I guess) was for an LT1 cam install. Anyway, I was comfortable with the work they did and it was cheaper than any other place I had found to do the cam, springs, and kit, in the Orlando area. Yeah, it's waaaaay too much, but, the book time accounts for not cutting corners or performing any tricks. It accounts for a timely and accurate cam install. Believe me, if I could have gotten it done right for $200-$500, I would have jumped on it in a heartbeat, but, how many people would guarantee their work for that price? I'm curious.
Old Jun 18, 2004 | 07:35 PM
ss rally red's Avatar
My friend & I (BLKWS6) on here have done multiple cam/spring swaps. We charge 400.00, and we keep every gasket/rocker arm bolts/crank bolts/etc, on hand to make sure the installation goes as smooth as possible and of course its done in 4.5-5 hrs. We are lucky to have access to a shop and any equipment needed. I believe that is a fair value to someone that doesn't have access to tools or a proper place to do the swap. And with a little notice we could line up a great LS1.edit tuner to get a base line tune in it the same day.
Old Jun 18, 2004 | 07:48 PM
Inspector12's Avatar
TT-TECH Veteran
Yeah I stand behind my work for $300 even. I also keep all the gaskets in stock and the oil pump pick up tube O-rings on hand crank bolts ETC... But I haven't done 30 so I know I am not as good as the superbowl cam changer. I think I know about all the short cuts there are and I do believe that you can do one of these in the time you suggest never have I tried to do a fast cam change just no need to get in a hurry it is not going anywhere till I am finished.LOL! But with that said I'll bet you just did cam and springs not oil pump no timming chain ETC...Most people not all want to do all or more than just cam and springs ETC...
Old Jun 18, 2004 | 07:52 PM
scalemaster's Avatar
well all I can say is that Inspector12 did my cam swap and no problems so far
Old Jun 18, 2004 | 07:57 PM
Was it cam and springs in 3 hrs I would like to see that also Cam only that would be fairly quick.
Old Jun 18, 2004 | 08:11 PM
WS-Sick's Avatar
If I drive over and have my cam installed by you I can get it tuned right afterwards? Is that on a dyno or just with LS1.edit? Either way, I would do that just for better drivability until I get a dyno tune if I even need one afterwards.
Old Jun 18, 2004 | 08:19 PM
SUX2BU's Avatar
yeah cam and springs in under 3 hours. i did a cam only swap once on my car in just under two hours. but that was before i did them alot.
i've only done one timing chain with a cam swap, all the others have been just your basic cam, springs, retainer and pushrods.
I am not bragging to be the "superbowl cam changer" i just do the work right and do it fast.
Old Jun 18, 2004 | 08:51 PM
TT-TECH Veteran
I am not picking on you just poking fun.LOL! Like I said I could probably do the same in the time frame just no need to. And I have been doing a lot more than just cam and spring swaps though. SUX2BU if you are ever in the Houston area look me up.
Jeff
Old Jun 18, 2004 | 09:04 PM
cz2898's Avatar
What a coincidence i just talked to a shop today to see what an install for a cam would be and by the 'book' the swap takes 15 hours, and he wanted to charge me $1150 labor WTF. Thats just over $77 an hour that costs more than my kit that im going to get. I guess im doing it myself cuz thats way to much.
Old Jun 18, 2004 | 09:58 PM
  #32
No dyno tune but he has a LOT of experience and could put a base tune in it that would be very close!
Old Jun 18, 2004 | 10:00 PM
  #33
Not questioning you at all but what spring tool do you use?
Old Jun 18, 2004 | 10:20 PM
  #34
SUX2BU's Avatar
the regular hand held one that autozone sells for 15 bux. i use that one for single springs and i made my own tool for the double springs.
Old Jun 18, 2004 | 10:55 PM
  #35
jrp's Avatar
jrp
SN95 Director
guess im the only one who does it to just help people, i dont charge anything.
Old Jun 18, 2004 | 11:16 PM
  #36
ChitownLS1's Avatar
Too bad you aren't in Chicago.
Old Jun 19, 2004 | 02:00 AM
  #37
Naked AV
Guest
Posts: n/a
Actually, I'm okay that he's not in Chicago...
Old Jun 19, 2004 | 03:55 PM
  #38
FirstGen's Avatar
SUX2BU, sent you a pm.
Thanks
Old Jun 19, 2004 | 04:53 PM
  #39
chupr0kabra's Avatar
Originally Posted by Inspector12
I'm in Houston and I charge $300 for cam and springs I also don't charge extra for timming chains or oil pumps while I am there. The price has just been argued down to here where I don't think any one would do it for less it is pretty easy with the right tools, but there is still a lot of stuff to take off and put back together ETC... I would love to charge $400-500 but some one would under cut me or anyone else for that matter so that is just where it ended up I know I won't do them for any less. JMO.
Jeff
Are you an at-home installer, or do you own a shop? I've been looking for a good performance/install shop in Pearland, since I live there and don't always want to make the drive to MTI.
Thanks,
-Mike
Old Jun 19, 2004 | 08:04 PM
  #40
10secondZ's Avatar
I do and I am right around the corner from you in lake mary. I charge $375.00 for cam and valvespring install, and give a 1 year 12,000 mile warranty against workmanship.I have done countless LS1 heads/cam installs and motor builds, my specialty is actually cylinder head porting for LS1/LT1 cars but I do installs as well, and for the thing's I do I beleive my prices are fair
Carter z28vf@aol.com
