Help picking parts for S/C build
A new Chevy Performance block
https://www.summitracing.com/parts/n...1166/overview/
Then one of these Texas Speed rotating assemblies (not sure on stroke yet)
https://www.texas-speed.com/p-787-ts...-assembly.aspx
Send my 243 heads out for a wicked port and polish / valvetrain build
http://www.advancedinduction.com/LSX...cGMLS2Head.php
and then a LSA supercharger with adapter plates to fit the 243 heads, a Walbro 450lph, and some big injectors.
Does this sound like a good plan, or is there something I am overlooking? Any recommendations on other parts to check out or on cam grinds for this setup?
Thanks!
I am using a mount kit desgined for an LS1, and I am not sure if the mounts are the same or if the headers would line up (custom swap headers)
I am using a 24x harness from PSIconversion along with their ECU, and I am not sure if that would work either.
Basically I want to have the built engine on a stand ready to drop in over a weekend if the LS6 in the car fails at some point during the season. What I don't want to do is re-engineer the whole swap, and I was under the impression that is what I would have to do to run the LS3
As for the crank, yes a 24x LS6 crank will swap into a Gen IV LS2/3 block, but of course you're going to want to check the bearing clearances. Even if you go with a forged 402/408ci rotating assembly, you can still get it with a 24x wheel and drop it into an LS2/3 block.
GMPP LS3 Block
https://www.summitracing.com/parts/n...3967/overview/
Texas Speed rotating assembly with 24x wheel
http://www.texas-speed.com/p-1020-ts...-assembly.aspx
(I would contact them before ordering to find the best combo for boost)
GMPP ported LS3 heads
https://www.summitracing.com/parts/n...8758/overview/
at this point is the LSA supercharrger going to be the bottleneck? How much power are the LSA's good for with supporting mods?
GMPP LS3 Block
