Question about LLSR on the street
Old Jun 29, 2016 | 11:26 AM
Darth_V8r's Avatar
Moderator
Originally Posted by bbond105
Would a set of Yella Terra adjustable rocker arms weigh too much to control? Using these rockers looks like it would take a lot of the work out of setting the valve train up.
yes they would make install easier BUT it's something that can work loose.
IMO I would use regular rockers and use shims. Everything just stays in place that way.
Regarding PITA it takes more effort on initial set up but that's it. If you do the shim method, I'm betting maintenance is minimal. Much less than adjustables
Old Jun 29, 2016 | 12:16 PM
bbond105's Avatar
I would be more concerned about the extra weight of the adjustment screw. If that is even an issue. I have never used the Yella Terra adjustable rocker arms but have used other brands on non LS engines and have never had a problem with the adjusters working loose.
Old Jun 29, 2016 | 02:50 PM
svede1212's Avatar
Originally Posted by thunderstruck507
I ran Castrol 0w30 European formula until the switch was made as to which was made in Germany, then switched to 0w40.
My question was to oil flow from different viscosities in a hydraulic lifter. The most important thing with oil viscosity seems to be in bearing clearance and oil pump capacity but it has to affect somewhat lifter fill and bleed. How much is the question.
Old Jun 29, 2016 | 03:17 PM
MaroonMonsterLS1's Avatar
I would assume the same way it would affect say, for example, a motorcycle shock. All else the same, you change damping rates in the front fork simply by changing oil viscosity. I would think a lifter would act in a similar manner. Thicker oil being stiffer and thinner oil being softer.
Old Jun 29, 2016 | 03:30 PM
jhshnh's Avatar
Good thoughts on the oil. I don't know the answer to those questions... someone with experience would have to chime in.
I currently use Royal Purple HPS 5w30, I get it at a nice discount because of where I work.
Old Jun 30, 2016 | 01:19 PM
Kip Fabre's Avatar
You will love the LLSR after the first up set zero maintenance. The post about the Hydraulic VS Solid cam is not a fair test. The solid has the advantage over the Hydraulic on this test. I do think the solid will make more TQ & HP even if the durations & Lift at the valve are the same. The Solid will be more stable at the higher RPM range than the Hydraulic.
Old Jul 1, 2016 | 07:15 PM
jhshnh's Avatar
How important is rocker arm selection?
Old Jul 1, 2016 | 07:50 PM
speedtigger's Avatar
Old School Heavy
I am on my second engine with the Cam Motion LLR. I have re-adjusted lash on both engines only once after breakin-in then never again.
What I can tell you is that the valve train is quieter than my previous Comp hydraulic setups, makes more power and revs to the moon.
One build utilized Jesel shaft rockers and the other T&D shaft rockers. Both of those rocker systems are excellent. I recommend spending the money on good rockers like the Jesel or T&D. It is one area where money is very well spent.
Here are two dyno videos of each engine. The first is a SBE 6 liter LQ9 on a chassis dyno, the 2nd it a 403" Dart Pro 1 LS3 headed LS2 on an engine dyno.
Old Jul 1, 2016 | 08:11 PM
scotty2000ss's Avatar
Dare I ask the admission fee for this slick set up?
Old Jul 1, 2016 | 08:29 PM
Old School Heavy
The only real cost difference between the LLR and a quality hydro setup is the cost of the adjustable roller rocker arms.
Old Jul 1, 2016 | 08:40 PM
I thought you could shim the non adjustable rockers to within spec?
Old Jul 1, 2016 | 08:44 PM
  #32
Old School Heavy
thunderstruck507 did it that way. He has a thread on it. Check it out.
Old Jul 2, 2016 | 05:58 AM
  #33
jhshnh's Avatar
[QUOTE=speedtigger;19315081]I am on my second engine with the Cam Motion LLR. I have re-adjusted lash on both engines only once after breakin-in then never again.
Wow. That's some serious power. How long and how many miles have you ran these engines?
Old Jul 2, 2016 | 06:16 AM
  #34
Old School Heavy
It is a weekend car. First engine probably had about 2500 miles on it when sold. This engine might have 500 miles on it so far.
Old Jul 2, 2016 | 03:16 PM
  #35
jhshnh's Avatar
Mine is a weekend car too, so I love what I see so far. Have you ran either at the track? I bet that 403 is an absolute monster.
Old Jul 2, 2016 | 05:23 PM
  #36
Old School Heavy
I have ran them both at the track. The 6 liter had countless track passes, tuning and refinement on it. It went as quick as 10.86@ 123 MPH in good weather at #3700 on motor. The 403 only has a few passes on it in the 1/8th so far. It went 6.60s @ 102-103 on motor with a tight nitrous converter, 3.73 gears and a 28" tire. The 403 is a beast and a lot of fun.
Old Jul 2, 2016 | 05:37 PM
  #37
jhshnh's Avatar
You've got me sold! That's exactly what I'm shooting for.
Old Jul 3, 2016 | 02:00 PM
  #38
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
It was speedtigger's detailed build thread/conversion with
His 6.0 to LLSR that convinced me to contact Kip for my
LLSR build.
Old Jul 3, 2016 | 07:34 PM
  #39
jhshnh's Avatar
LLSR build.
Is your build done? Please share!!
Old Jul 3, 2016 | 07:37 PM
  #40
jhshnh's Avatar
So here's a question... for a 346, what would be the best heads for a llsr setup with 4k stall and 4.10 gears? Basically a all out engine? I assume the TFS 215s, MMS 220s, or MAST small bore LS3s?
